eurocamper1 Posted April 16, 2013 Share Posted April 16, 2013 I wanted to ask what the best oil for rear end with limited slip is Also where is the fill plug Thanks Henrik Quote Link to comment Share on other sites More sharing options...
399Road Posted April 17, 2013 Share Posted April 17, 2013 I use Castrol B373 LSD oil. The filler is the plug in the backplate of your axle. Make sure your car is level when filling it up. ...Luke. Quote Link to comment Share on other sites More sharing options...
611 Posted April 17, 2013 Share Posted April 17, 2013 Is it original Opel diff? If so andyC on here got me some vauxhall diff oil with an extra additive for the limited slip. I can get you part numbers if needed? Andy Quote Link to comment Share on other sites More sharing options...
mantasrme Posted April 18, 2013 Share Posted April 18, 2013 When the car is sat on the floor the fill plug is cunning hidden right behind the panhard rod on the right side of the diff cover. Also incase you don't know the oil can be drained by removing the bottom centre cover bolt, it has a drain gallery idden behind it. 1 Quote Link to comment Share on other sites More sharing options...
