Denis K Posted May 24, 2013 Share Posted May 24, 2013 Is there a difference in the rear prop that fits inside the torque tube between the 1.8 and 2 litre mantas lads?? Quote Link to comment Share on other sites More sharing options...
rutts Posted May 24, 2013 Share Posted May 24, 2013 no difference that i know of. Quote Link to comment Share on other sites More sharing options...
Brown Job Posted May 25, 2013 Share Posted May 25, 2013 Yeah, it would depend not on engine size but original gearbox fitted. The 4-speed boxes and 5-speed boxes are fitted with different props due to length of the box assembly. Don't see any reason why 2 5-speeders would vary, onlt the axle ration would be different. BJ Quote Link to comment Share on other sites More sharing options...
spiney_norman Posted May 25, 2013 Share Posted May 25, 2013 Yeah, it would depend not on engine size but original gearbox fitted. The 4-speed boxes and 5-speed boxes are fitted with different props due to length of the box assembly. Don't see any reason why 2 5-speeders would vary, onlt the axle ration would be different. BJ Front props are different on 4 and 5 speed cars, but the rear section inside the torque tube's the same. As far as I know the only difference is between the 1300 OHV engined cars (which had a much smaller axle) and everything else. Quote Link to comment Share on other sites More sharing options...
Denis K Posted May 25, 2013 Author Share Posted May 25, 2013 Cheers for all the info lads. Much appreciated Quote Link to comment Share on other sites More sharing options...
mantadoc Posted May 26, 2013 Share Posted May 26, 2013 Front props are different on 4 and 5 speed cars, but the rear section inside the torque tube's the same. As far as I know the only difference is between the 1300 OHV engined cars (which had a much smaller axle) and everything else. Correct, only thing I would add is the 16N (I think) designed to run on 2 star had the same BHP as the 1196cc (57 I think) and got the smaller axle too. Barring that I believe all CIH engined cars got the bigger axle. Quote Link to comment Share on other sites More sharing options...
