Mantney Posted September 6, 2013 Share Posted September 6, 2013 ok mate no rush Sorry for such a delay. You must think I'm a right tool. Quote Link to comment Share on other sites More sharing options...
JackA1972 Posted September 9, 2013 Share Posted September 9, 2013 hi there, if not needed, would you be willing to sell me the throttle cable and maybe the carb with linkages? thanks jack Quote Link to comment Share on other sites More sharing options...
Mantney Posted September 9, 2013 Share Posted September 9, 2013 hi there, if not needed, would you be willing to sell me the throttle cable and maybe the carb with linkages? thanks jack Hello Jack, I dont intend selling the throttle cable as you can appreciate they are difficult to get hold of, that one is not the best but i was planning to keep it as a just in case. However everything is for sale at the right price. Did yours not have one or has it snapped? If you want I could take some detailed photos of the one i had from Mark Kinnon and measure it if you want. Regarding the Weber Carb, its open to sensible offers, it is of unknown provinance so i make no promises for it but probably needs overhauling, Also it is still attached to the manifold as i do not have the the correct tool to remove the bolts, ther is no air filter either. Again i can take some detailed photos if you want. Quote Link to comment Share on other sites More sharing options...
JackA1972 Posted September 9, 2013 Share Posted September 9, 2013 yeh understood am having problems locating one. if you could measure the length that would be fantastic. im amusing the carb would be set up for the 1900 engine, jet wise. is it a 32/36? Quote Link to comment Share on other sites More sharing options...
Shug Posted September 9, 2013 Share Posted September 9, 2013 Don't suppose the white plastic door clips the arm rest/handle screws into are available? Also need the winder handle retaining clips. Quote Link to comment Share on other sites More sharing options...
Mantney Posted September 9, 2013 Share Posted September 9, 2013 Don't suppose the white plastic door clips the arm rest/handle screws into are available? Also need the winder handle retaining clips. Not sure, is that like a gromet or plug that would be popped into the steal of the door? Quote Link to comment Share on other sites More sharing options...
Mantney Posted September 9, 2013 Share Posted September 9, 2013 yeh understood am having problems locating one. if you could measure the length that would be fantastic. im amusing the carb would be set up for the 1900 engine, jet wise. is it a 32/36? Probably is set for the 1900 as thats what its off, but you never know, i believe it is a a 32/36 Quote Link to comment Share on other sites More sharing options...
Shug Posted September 9, 2013 Share Posted September 9, 2013 Not sure, is that like a gromet or plug that would be popped into the steal of the door? There are 4 square holes in the middle of door. 2 of them will have white plastic inserts that a screw goes in to from the arm rest. Quote Link to comment Share on other sites More sharing options...
611 Posted September 9, 2013 Share Posted September 9, 2013 Hey Shug If Mantney dosnt have any i might have something as i have a few pots of bits in the loft. Will be able to have a look mid week. I know the ones you mean for the door handles and the clip for the winder. Andy Quote Link to comment Share on other sites More sharing options...
Mantney Posted September 10, 2013 Share Posted September 10, 2013 yeh understood am having problems locating one. if you could measure the length that would be fantastic. im amusing the carb would be set up for the 1900 engine, jet wise. is it a 32/36? yeh understood am having problems locating one. if you could measure the length that would be fantastic. im amusing the carb would be set up for the 1900 engine, jet wise. is it a 32/36? Approximately 130cm I would measure the original for you but it's not at home at the moment Quote Link to comment Share on other sites More sharing options...
Mantney Posted September 10, 2013 Share Posted September 10, 2013 (edited) There are 4 square holes in the middle of door. 2 of them will have white plastic inserts that a screw goes in to from the arm rest. are these they? If so I can only find 3, you're welcome to them if you send me a stamped addressed envelope, unless you want to see if andy can do you a full set. don't have the winder clips. Edited September 10, 2013 by Mantney Quote Link to comment Share on other sites More sharing options...
611 Posted September 10, 2013 Share Posted September 10, 2013 Shug I would go for those and I will see if I can find the 4th one and the winder clip tomorrow. Andy Quote Link to comment Share on other sites More sharing options...
Shug Posted September 10, 2013 Share Posted September 10, 2013 are these they? If so I can only find 3, you're welcome to them if you send me a stamped addressed envelope, unless you want to see if andy can do you a full set. don't have the winder clips. Thats the ones! I only need 2 of them. PM me your address and I'll sent you a sae. Quote Link to comment Share on other sites More sharing options...
Mantney Posted September 10, 2013 Share Posted September 10, 2013 Thats the ones! I only need 2 of them. PM me your address and I'll sent you a sae. Pm sent Quote Link to comment Share on other sites More sharing options...
611 Posted September 10, 2013 Share Posted September 10, 2013 Shug Just as well that you only need 2 as i had a quick look through my box of stuff and i think i must have every other type of clip, screw, nut bolt etc.. off a A, but not the door ones :-) I have found one window winder clip so far but need to get up and have a good look. Also need to get rid of some stuff! will see what i can find tomorrow. Andy Quote Link to comment Share on other sites More sharing options...
JackA1972 Posted September 12, 2013 Share Posted September 12, 2013 Probably is set for the 1900 as thats what its off, but you never know, i believe it is a a 32/36 could you send some photos if possible please jack Quote Link to comment Share on other sites More sharing options...
Mantney Posted October 1, 2013 Share Posted October 1, 2013 Would anyone be interested in buying the shell as an extensive restoration project? Initial enquiries suggest that that it may be 1973 built. Quote Link to comment Share on other sites More sharing options...
