calmk3gt Posted June 18, 2013 Share Posted June 18, 2013 right i need flywheel bolts as the ones removed are in no shape to be put back in! i've gone to my local fasteners supplier and were both scratching our heads! tried looking around on the net to no avail so was wondering if anyone could shed some light on my never ending problems!? part numbers or just recommended shops to get them from!? thanks! as soon as this problems fixed its the thread next and shows through whats left of the summer! Quote Link to comment Share on other sites More sharing options...
611 Posted June 18, 2013 Share Posted June 18, 2013 They are a strange pitch, had the same problem myself. Also one will be a locator bolt so you get the flywheel in the correct location. Got mine from here; http://www.ebay.co.uk/itm/Schraubenset-Schwungrad-Schwungradschrauben-Opel-cih-mit-Passschraube-/200903253415?pt=DE_Autoteile&hash=item2ec6c45da7 You will need a bit of google translation :-) he takes pay pal, very quick delivery and all the stuff i have had from him has been good. And he has an amazing Ascona ;-) http://www.edelschmiede.com/ hope this helps Andy Quote Link to comment Share on other sites More sharing options...
rutts Posted June 18, 2013 Share Posted June 18, 2013 I just went to Vauxhall and bought some from stock. maybe I was lucky. Quote Link to comment Share on other sites More sharing options...
611 Posted June 18, 2013 Share Posted June 18, 2013 Depends on your vauxhall dealer :-) mine are a bunch of useless buggers. No part number no help :-( Andy Quote Link to comment Share on other sites More sharing options...
Lesis Posted June 26, 2013 Share Posted June 26, 2013 Also one will be a locator bolt so you get the flywheel in the correct location. Those this "P" bolt goes in to any flywheel/crank hole or it should be put in the right one? Quote Link to comment Share on other sites More sharing options...
611 Posted June 26, 2013 Share Posted June 26, 2013 (edited) You should find that the "P" bolt will only go into one of the holes the shoulder is a different size to the rest so you cant go too far wrong. I can scan that section from the opel workshop manual if that will help? Andy Edited June 26, 2013 by 611 Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted June 28, 2013 Share Posted June 28, 2013 P bolt goes into the offset hole in the crank, it is a locator bolt. You can always have the crank dowelled for extra security. Chris Quote Link to comment Share on other sites More sharing options...
calmk3gt Posted July 3, 2013 Author Share Posted July 3, 2013 cheers for the replies guys! shes all bolted back up now and running like a dream! just need an M.O.T and the carbs setting up! will start my thread shortly! Quote Link to comment Share on other sites More sharing options...
