Manta 1.8 Coupe
Ems
I'm planning on selling my Manta in the next couple of months, any idea on what it's worth or should I just put it on ebay or break it?
The good bits:
All bushes (except for rear anti roll bar) have been changed for superflex
Spax adjustable dampers all round
Choice of either +40mm or -40mm springs
SD rollcage with removable diagonal & door bars
Blydenstein B+ Head with mk1 Astra GTE injection system or alternatively I could replace it with the original head and weber carb
All welding has been done to chassis, floor, etc.
Irmscher early type twin headlight kit
Fibreglass bonnet
Disc brakes on back
Bias Pedal Box
4 branch manifold
Magnecor KV85 leads
Choice of (Manta B) black bumpers that give more clearance on front or standard bumpers
Adjustable Panhard Rod
GTE alloys in either white, silver or black/silver
Bad Bits
Ex road rally car so hasn't had a easy life!
Bodywork - needs filling and painting
Rollcage could do with repainting
Sunroof has been plated and filled
Needs new dash top & roof lining
Brake lines and fuel line are inside the car, but one of the fuel lines need changing
To be removed from the car and replaced with standard items where applicable, unless someone wants to make a serious offer:
ZF LSD axle with steel torque tube
Wilwood midlite brake kit
Quick Rack with 2 new stainless uv joints
TAS hydraulic handbrake
Sump Guard
Omex rev limiter
KC daylighters (inner headlamps)
Quick release steering wheel
Many spares also available at extra cost
Edited by Ems
Oh bottom, just as I think about running a Manta in some form of motorsport possibly sprints you go and post this. Its exactly the sort of thing I'm looking for other than its not an A series, for which I have a load of parts. Decisions, decisions My only question is how much? :wacko:
The A series will be eligible for historic series, as for my car I have no idea what it's worth.
I've had the car 15 years and had loads of fun in it, I hate doing bodywork and lost interest in it over the years but I still drive it daily to work.
Ideally the roof would need changing as the filler keeps cracking, I've got a replacement in the shed.
I would also change the arches again if I was keeping it as my friend put these on and got the panels to hot so they warped meaning too much filler. Better still replace the rear quarters with the panels that Titson is selling
I don't blame you for the shameless plug! It's already been used for road rallying - the car was better than the driver!
When I rallied it, the brakes were off a 2.2 Carlton, the axle had no lsd and the engine was standard apart from the weber carb.
Emyr, bad news you are selling, I have only met you a couple of times but I hope you will remain involved in the club. You have been really helpful to me and your Manta decals were superb! I must get those GT/J decals off you too!
