Sutty2006 Posted August 6, 2013 Share Posted August 6, 2013 Ok..... so the manta made it to Billing and back under its own steam (unlike the mondeo which got towed in the end)... and now im on to tidying up the niggly bits of the conversion. So my first issue is induction clearance on the bonnet. The standard injection manifold had an elbow on it made from rubber. My brothers ecoshite calibra has the same pipe.... and you can just about make it out on this pic.. So I bought a power cap..... And this too hits the bonnet, a lot.... but to me it doesnt look right. What do you think? Theres no way im modifying the bonnet. I did that for the 2.0L 8valve I dropped in and I want to keep the standard look on the exterior. Whats everyone else done to clear the bonnet? Show me some picks! I have another question! The power cap I bought came with an Airflow meter and a rather buggered k and N cone filter. The airflow meter has a bigger electrical plug than the one on my Redtop, yet the one i bought was listed for an XE? any reason for this? Quote Link to comment Share on other sites More sharing options...
garymanc Posted August 6, 2013 Share Posted August 6, 2013 (edited) [url=http://s238.photobucket.com/user/gary16v/media/billin6_zpsde717c45.jpg.html][/uR L] not sure about your AFM looks very different to what i have seen before , not sure if there is two types of throttle body , pm me your address steve got a nice set of bolts for your powercap Edited August 6, 2013 by garymanc Quote Link to comment Share on other sites More sharing options...
yellowhusaberg Posted August 11, 2013 Share Posted August 11, 2013 two sorts afm on the red top engines. upto 1993 hot wire setup(big plug)motronic 2.5 ecu after 1993 hot film setup(small plug)motronic 2.8 ecu you have the hot film setup on your car,i have red top in my coupe with on clearance probs,i checked the overall height of the cap and it's 70mm Quote Link to comment Share on other sites More sharing options...
biffy1984 Posted August 12, 2013 Share Posted August 12, 2013 My powercap also hit the bonnet and dented it outwards, couldn't lower the engine any further as the sump was nearly touching the steering rack so I got a mate to mill a few mm off the face of the powercap. No more problems. Quote Link to comment Share on other sites More sharing options...
