Oil Pressure Gauge
Robert1234
this is usually caused by a loose wire on the sender unit.1 wire operates the oil light.1 wire operates the guage.sender unit is under the exhaust manifold at the side of the engine near the back. (on a cam in head engine) fiddly to get at .you may find that a good press on the terminals may do the trick because to replace the leads can be very awkward.(one is on a spade but the other is on a 8mm lug)
  • 3 months later...
UPDATE!
I had a go at sorting this today only to find that the two wires weren't connected to anything!
I cant see the sender at all, what does it actually look like and can anyone tell me exactly where it is, i dont really want to have to take manifolds off at this time of year!
Thanks
Rob
