Ems Posted March 24, 2014 Share Posted March 24, 2014 I need to fit longer wheel studs on the rear axle, the old ones have been removed. What the best way of fitting the new ones? Thanks Quote Link to comment Share on other sites More sharing options...
stradacab Posted March 24, 2014 Share Posted March 24, 2014 They are an interference fit. Put a nut on and whack em out the back of the hub. If they are stubborn, heat the hub with a torch. Fit the new studs but winding them through usung a wheel nut Quote Link to comment Share on other sites More sharing options...
poddy Posted March 24, 2014 Share Posted March 24, 2014 i find it easier to press them in , tried to pull them on with a nut but too tight .. 1 Quote Link to comment Share on other sites More sharing options...
Ems Posted March 25, 2014 Author Share Posted March 25, 2014 Tried winding the new ones through with a wheel nut, didn't work. I'll take them to get pressed in. 1 Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted March 26, 2014 Share Posted March 26, 2014 Eric the car guy on youtube uses an air hammer, not tried that but looks good. I pull mine in using a spacer and upside down standard wheel nut. The nut takes some punishment and only does 4 studs Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted March 26, 2014 Share Posted March 26, 2014 (edited) I just use a few washers and an upside down wheel nut, plenty of oil on the threads. Tighten the nut then hit the rear of the stud with a big hammer/drift, retighten the nut, repeat. Its always worked for me. Edited March 26, 2014 by lamchop77 2 Quote Link to comment Share on other sites More sharing options...
Ems Posted April 2, 2014 Author Share Posted April 2, 2014 Does anyone know if standard length wheel studs are still available? Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted April 16, 2014 Share Posted April 16, 2014 Try speedshack if they don't have them nobody will!!!! You can always just shorten the longer one of course. Quote Link to comment Share on other sites More sharing options...
