mcintbg Posted July 2, 2014 Share Posted July 2, 2014 would this fit my manta a ? Quote Link to comment Share on other sites More sharing options...
Snowy Posted July 2, 2014 Share Posted July 2, 2014 You would need to modify the linkage and adapt the gearbox cross member. Also the four speed prop doesn't fit the five speed and I cannot remember if the B series is a straight swap. But yes you can fit this box with a bit of work. Quote Link to comment Share on other sites More sharing options...
mcintbg Posted July 2, 2014 Author Share Posted July 2, 2014 thx ! Quote Link to comment Share on other sites More sharing options...
Shug Posted July 2, 2014 Share Posted July 2, 2014 (edited) You need to shorten the prop from a B as well. By about 5cm if I remember right. (measure first tho!) Edited July 2, 2014 by Shug Quote Link to comment Share on other sites More sharing options...
611 Posted July 3, 2014 Share Posted July 3, 2014 (edited) I think the prop from an automatic A series is a straight fit? Linkage shortening is quite easy. Not sure if retro power do one for the A? and i think you can get the modified gearbox cross member and mount from this guy http://www.edelschmiede.com/ if not i have a link somewhere. I can post a pic of the linkage as im just about to re-fit mine after a box refurb. also you can get all the gearbox seals/spares from http://www.edelschmiede.com/ Andy Edited July 3, 2014 by 611 Quote Link to comment Share on other sites More sharing options...
