Door Lock Barrel With Keys
colinebrooks
Thanks for your help, took the barrel out,it got a plastic cam with sought of pegs on it  which i can"t get off,drill a hole in the spindle and screwed with a washer and the key will not turn cam being clamped to the body A small piece of metel broken off between the spring.pulled it out and the key goes right round without the cam,Help.Thanks,   Colin       .
thanks for the help but the barrel not the same, my has a camber on the bottom that pulls the lock on when you turn the key, and a slider that holds it door they say in the advert manta up to 82 but this is not correct mind is 1978 and its not the same thanks for your help,any help is welcome thanks again
Do you want the barrel or the entire assembly??
