bris jas Posted October 9, 2014 Share Posted October 9, 2014 Just a quick question regarding fitting a remote servo to my bias pedal box set up. I've never had great brakes since installing this set up, they stop but no lock up. Running Saab front calipers and volvo rears, master cylinders are correct as mentioned before. Friend who had similar problems on his kit car fitted a remote servo and seemed to sort his brakes. I would have to fit a dual system or 1 to the front and 1 to the back. Any thoughts on this? Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted October 10, 2014 Share Posted October 10, 2014 I'm sure someone on here has fitted a servo to just the front system jason, possibl Chris (mantaray) Quote Link to comment Share on other sites More sharing options...
tony g Posted October 11, 2014 Share Posted October 11, 2014 The brakes wont be more efficient with a servo just "assisted" If you press really hard will they lock then? A servo is just a big muscle to help. Hope that makes sense Tony Quote Link to comment Share on other sites More sharing options...
bris jas Posted October 12, 2014 Author Share Posted October 12, 2014 No they won't lock up on tarmac/concrete, gone through everything with the braking system checked and double checked and all is how it should be. From what i've been informed a 1.2 ratio servo will put double the pressure to the brakes from what i can press, the calipers i have front and back are both from vehicles fitted with servos. If not servo i'm lost to what it can be? Quote Link to comment Share on other sites More sharing options...
wayne ingham Posted November 22, 2014 Share Posted November 22, 2014 I have fitted stainless brake line kit ,The brakes are lot more improved , Replaed the brake fulid,The price of the parts will not cost over £60.00.it will be a 2 hour job Quote Link to comment Share on other sites More sharing options...
