Kevin Abbott Posted January 10, 2015 Share Posted January 10, 2015 I'm nearly ready to blast the car after I've removed the last of the underseal. I want it completely bare before I blast but these bump stops seems very well stuck in. Can anyone tell me how to remove them without destroying them? Ta Quote Link to comment Share on other sites More sharing options...
mantadoc Posted January 10, 2015 Share Posted January 10, 2015 Large flat screw driver inserted in the nick either in front or behind and lever / then slide it out. The part you cannot see it a T cross section with the triangle view being the vertical of the T and the "ears" of the T being to the outside and middle of the car inside the rail. IIRC one end of the slot they are in is also Teed to make them easy to fit. Best choose the right end even though invisible. Probably the rear Quote Link to comment Share on other sites More sharing options...
stradacab Posted January 10, 2015 Share Posted January 10, 2015 I squirted wd40 and gripped either side with a big set of swan necks and rocked them out. Didn't do damage, they are pretty sturdy Quote Link to comment Share on other sites More sharing options...
paulmanta Posted January 10, 2015 Share Posted January 10, 2015 Pretty much how I do it, I do warm them up a bit first though, not hot just warm them with a heat gun n low to make them supple. Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted January 10, 2015 Author Share Posted January 10, 2015 Result. Tried the screwdriver and it didn't want to come out without ripping. The water pump pliers and wiggle did the trick :-) Thanks for the help everyone. Just what being in the club is all about 3 Quote Link to comment Share on other sites More sharing options...
