Aggressor Posted April 8, 2015 Share Posted April 8, 2015 im doing an xe conversion on my manta and will be fitting twin 45's to it. what brake servo will i need?. Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted April 9, 2015 Share Posted April 9, 2015 Could use a vacuum pump either belt driven or electric rather than tap the manifols and cause running hassle. Quote Link to comment Share on other sites More sharing options...
MicsManta Posted April 9, 2015 Share Posted April 9, 2015 there generally is no real effect from tapping of one port because when your braking you normally are not using the throttle. but a easy solution as said before by paul use a vac pump. Quote Link to comment Share on other sites More sharing options...
Aggressor Posted April 10, 2015 Author Share Posted April 10, 2015 Thanks guys I will give that some thought Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted April 18, 2015 Share Posted April 18, 2015 There was a great thread about using a golf or polo servo and MS that is now buried in the forum somewhere Quote Link to comment Share on other sites More sharing options...
Aggressor Posted April 22, 2015 Author Share Posted April 22, 2015 Yes that's right will have to look for that.. Thanks kev Quote Link to comment Share on other sites More sharing options...
