Indicator stalk/arm, wiper control assembly
Rick-Manta
I'm looking for the indicator and wiper control arm/stalk/lever/thingy if anyone has one please? The twist bit has broken on mine which has left the wipers stuck on fast wipe and the washer button doesn't work either. I'll need the entire assembly that bolts and plugs onto the column housing and obviousy no floppy, near knackered ones as it'll probably break soon like mine has.
I can paypal pal, Many thanks pal.
#### EDIT ####: I forgot to add that I can't reply to posts in Parts Wanted (a site bug perhaps) and I think edits are limited too?
Chris, thanks very much for the piccy, that's exactly what I'm after but really didn't expect to find a completely new one. I can't afford to pay £80 unfortunately otherwise I'd jump at it over a second hand one from a breaker/donor car. Thanks again for taking the time to picture it though.
Edited by Rick-Manta
On ‎28‎/‎01‎/‎2016 at 9:46 PM, mantaray said:
tn_20160103_184237.jpg.1fd3cef40d384c395
Is this the one? If so ,it is new in box £80 + P&P
Will that fit the MK1 cavalier coupe? I think it should be the same.
If so I would give you £80 posted?
Thanks
