halley cockburn Posted May 15, 2016 Share Posted May 15, 2016 Hi All , Can anyone advise on the job to remove a sunroof on manta GTE thanks 1 Quote Link to comment Share on other sites More sharing options...
Dimpas Posted April 12, 2018 Share Posted April 12, 2018 Need this info too ! Quote Link to comment Share on other sites More sharing options...
Danny D114BCW Posted April 12, 2018 Share Posted April 12, 2018 You need to release the headlining (it clips off the front and hangs down) you then have some screws (8 of) on the inside which hold brackets/sliders into the channel. Ensure you familiarize yourself with how the sunroof operates and how and where each part goes. It is then a matter of teasing the panel out. Refitting isn't the easiest job which is why i said ensure you fully understand how it works and which part goes where. 1 Quote Link to comment Share on other sites More sharing options...
Julian Posted April 12, 2018 Share Posted April 12, 2018 2 hours ago, Danny D114BCW said: You need to release the headlining (it clips off the front and hangs down) you then have some screws (8 of) on the inside which hold brackets/sliders into the channel. Ensure you familiarize yourself with how the sunroof operates and how and where each part goes. It is then a matter of teasing the panel out. Refitting isn't the easiest job which is why i said ensure you fully understand how it works and which part goes where. When I tackled that job a few years back, I took many photos as I was pulling it apart. and really needed them on assembly!!! It is a tricky little job. I should have kept the photos, if it wasn't for photobucket I would have put them on here. 1 Quote Link to comment Share on other sites More sharing options...
Dimpas Posted April 12, 2018 Share Posted April 12, 2018 I really like to see these photos ! Quote Link to comment Share on other sites More sharing options...
