yeti132 Posted September 6, 2016 Share Posted September 6, 2016 Can anyone give me some advice going to put a 2.4 Cih in my car as anyone any diagrams on the wiring loom needed for the job regards gary Quote Link to comment Share on other sites More sharing options...
andyc Posted September 6, 2016 Share Posted September 6, 2016 A lot will depend on what intake set up you intend to use and what ECU set up Andy Quote Link to comment Share on other sites More sharing options...
yeti132 Posted September 7, 2016 Author Share Posted September 7, 2016 I have a Monza inlet ready to cut down was going to use the Ecu out of the frontera but all so like the dbalis set up you can buy because they is no cutting needed what do you would be best Quote Link to comment Share on other sites More sharing options...
andyc Posted September 7, 2016 Share Posted September 7, 2016 Never heard antone using a Frontera unit and i thing you might have a job sorting the the wiring. The last one i done was to use a 2.2 Carlton Manifold with Frontera/2.4 injectors. The wiring loom was a modded 2.4 Omega/Carlton and the ecu was out of the same. As this system is a Motronic set up the harness is more or less plug and play into the Manta Loom Quote Link to comment Share on other sites More sharing options...
mantadoc Posted September 7, 2016 Share Posted September 7, 2016 The Frontera wiring is actually very simple on the Motronic 1.5 Years ago I wrote to Haynes and said I had bought the Manta Manual and was fitting a Frontera engine and didn't really want to buy the Frontera manual just for the wiring. They sent me the complete wiring section for the Motronic 1.5 Biggest job with the Frontera is the loom is not separate from the Frontera loom (I have one one cut down on the Frontera engine I acquired in 1999 complete with 2.2 Plenum and the dip stick tube welded into the side of a Manta sump to save drilling block) Quote Link to comment Share on other sites More sharing options...
611 Posted September 7, 2016 Share Posted September 7, 2016 I have a Frontera manual (if i can find it in the packing!!) not sure what it has in it wiring wise as wasn't using any of the loom on mine. I can have a look for it at the weekend if it helps? Andy Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted September 9, 2016 Share Posted September 9, 2016 Gary, Guy i used to know ran 2.4 mantas for oval racing (superbangers at Warton, Carnforth). He had his own garage/rolling road set up and he reckoned that using the 2.0 injection on the 2.4 motor as std gave about an extra 7 bhp with no mods over the std 2.4. All you need to do to fit the 2.0 system is alter the plenum mounting position to realign the ports (needs a hole drilling for the dowel on the head into the 2.0 plenum) and make up some thick/loger washers to hold the inlet and exhaust manifolds to the head. Everything can then run on your std 2.0 setup, you just need to get the fuelling set up. Really wants an adjustable reg to wind up the pressure to about 3.5 bar. The std 2.0 injectors are good for about 150bhp with this setup. HTH Chris Quote Link to comment Share on other sites More sharing options...
yeti132 Posted September 9, 2016 Author Share Posted September 9, 2016 Thanks used to go to warton good banger track also would like to thank everyone for there advice and comments Quote Link to comment Share on other sites More sharing options...
