Aditi Posted May 2, 2017 Share Posted May 2, 2017 Greetings Oil leakage - Differential : Especially strange that it is from there and not was from the gasket.. And what oil is recommended EP90 or EP80 ? Quote Link to comment Share on other sites More sharing options...
BIG STU Posted May 2, 2017 Share Posted May 2, 2017 Good morning. The leak willl be coming from the pinion seal that is situated at the front of your diff... if you split your diff from the extension housing, yo will see the leaking seal. Its a straight forward job to do. You can buy a new seal off ebay for a couple of quid. Good luck Stuart. Quote Link to comment Share on other sites More sharing options...
Danny D114BCW Posted May 2, 2017 Share Posted May 2, 2017 EP90 is the oil to use as far as I know. Quote Link to comment Share on other sites More sharing options...
BIG STU Posted May 2, 2017 Share Posted May 2, 2017 Cheers Danny. I forgot to mention that on my response. 90s it is. good luck. Quote Link to comment Share on other sites More sharing options...
Aditi Posted May 30, 2017 Author Share Posted May 30, 2017 Thank you Something has a chart or pictures of the Thanks a lot, Someone has a chart or a picture of this pinion so i know exactly what to buyThank Quote Link to comment Share on other sites More sharing options...
Aditi Posted June 17, 2017 Author Share Posted June 17, 2017 Does someone knows the specs of the rear axle oil pinion seal or it's manufacturer part number? thnx for helping. Quote Link to comment Share on other sites More sharing options...
BIG STU Posted June 18, 2017 Share Posted June 18, 2017 Go on ebay uk and you will find what you require. Good prices.. Quote Link to comment Share on other sites More sharing options...
611 Posted June 19, 2017 Share Posted June 19, 2017 On 6/18/2017 at 00:56, Aditi said: Does someone knows the specs of the rear axle oil pinion seal or it's manufacturer part number? thnx for helping. This is probably the one, but email Thomas to check first and he will make sure you get the right one. tn@edelschmiede.com https://www.edelschmiede.com/shop/Shaft-seal-ring-differential-rear-axel-drive-input-large-cih-rear-axel Andy If you need a part number i can probably get one as i usually keep spares so i can find out in the next day or two if you need me to. Andy Quote Link to comment Share on other sites More sharing options...
