hydraulic Clutch
yeti132
Just about to fit the pull type master cylinder to my A series. Had a mounting bracket made, but waiting for it to come back from the powder coating place.
some info on one here.
http://www.opelgt.com/forums/7a-clutch/76121-hydraulic-clutch-ideas.html
my bracket and will have some more pics soon of the setup.
http://www.theopelproject.com/?p=1148
http://www.rallydesign.co.uk/product_info.php?products_id=4080
I did think about the push type in the bell housing but as the box is such a bugger to get out of the A i decided it could be a pain in the ass to setup and if you had issues.
What you running on the 2.4 spec wise? injection or carbs? (just interested, nothing to do with the clutch :-)
Andy
Yes Andy going to run 2.4 cih injection mite change mine on gearbox I have the r25 cih same side for the starter motor but because its hydraulic mite going for the gte gearbox because it's cable and mite be interested in your Monza flywheel and clutch but will check if Dave as spoke to you for it yet
This is a shot of a RetroPower build and where they added a bracket for a hydraulic clutch in progress. Top of pedal was changed to attach pushrob to and cylinder sitting towards driver. Had this stored away for furture reference if i needed it.
Hey Gary
I have not seen the r25 so not sure on the setup of those. Im running full throttle bodies and use to hate the way the clutch cable went across them so im doing the pull master cylinder.
I have still got the clutch and flywheel as not heard from Dave. Its sat in the conservatory in the dry which annoys the missus, so if your interested make me an offer as it would be good for it to go to a good project as i now have the S10 all fitted up on mine.
let me know.  Andy
