Manta8 Posted October 17, 2017 Share Posted October 17, 2017 I need to replace the starter motor on my 1.8 Hatch but I am unsure of the best approach. It appears very difficult to get to from above with the carb and inlet manifold present. From below it is possible to get to the two bolts that attach it to the bell housing but I think the rear is supported by a bracket that I cannot get to. What is the best way to remove and replace the starter motor ? Any tricks or hints would be appreciated. Cheers. Quote Link to comment Share on other sites More sharing options...
Snowy Posted October 18, 2017 Share Posted October 18, 2017 (edited) 8 hours ago, Manta8 said: I need to replace the starter motor on my 1.8 Hatch but I am unsure of the best approach. It appears very difficult to get to from above with the carb and inlet manifold present. From below it is possible to get to the two bolts that attach it to the bell housing but I think the rear is supported by a bracket that I cannot get to. What is the best way to remove and replace the starter motor ? Any tricks or hints would be appreciated. Cheers. The easiest way is to take the inlet manifold off as you have easy access to all the connections and fasteners. The inlet manifold is very easy to remove and the gasket only costs seven pounds or so. You can do it from under the car but like you say you're doing it by feel rather than sight. One last thing please don't forget to disconnect the battery. Edited October 18, 2017 by Snowy 1 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted October 18, 2017 Share Posted October 18, 2017 Snowy hit the nail on the head. Theres no straight forward way of changing it. If you have access to a ramp/pit then from underneith is the way forward. If not, take the inlet manifold off and you'll see it perfect from there. Quote Link to comment Share on other sites More sharing options...
garymanc Posted October 18, 2017 Share Posted October 18, 2017 fit one from a c20xe engine there a fair bit lighter than the 1.8 starter so no need to fit the bracket you may need to alter a terminal on the wiring IIRC Quote Link to comment Share on other sites More sharing options...
Manta8 Posted October 28, 2017 Author Share Posted October 28, 2017 Thanks to everyone for the words of advice. I think I will be removing the inlet manifold and tackling it from above. Cheers Quote Link to comment Share on other sites More sharing options...
