Manta hatch Posted January 3, 2018 Share Posted January 3, 2018 Hi I have Astra gte calipers and Audi machined discs on my mk1 cavalier I have used 1800 manta flexi hose but the calipers bango touches the springs on full lock is there a way around this different hose may be ? Cheers Quote Link to comment Share on other sites More sharing options...
wayne ingham Posted January 3, 2018 Share Posted January 3, 2018 I used braided hoses ,l removed the ends from the braided hoses and fitted ends that bent away from the road spring Quote Link to comment Share on other sites More sharing options...
mantasrme Posted January 4, 2018 Share Posted January 4, 2018 Have you removed the lug from the caliper next to where the banjo sits? This is to hold the end at the right angle for the astra but its the wrong angle for the manta, if you file this down you should be able to use the standard hose (be careful not to get debris in the actual caliper!) 1 Quote Link to comment Share on other sites More sharing options...
