IanMc Posted January 7, 2018 Share Posted January 7, 2018 Could somebody please confirm that my brake fluid reservoir should have wiring to it. I seem to recall that my previous Coupe's had this to complete a circuit and light a lamp on the dash when the fluid is low of course. Strangely my Haynes manual does not mention it, either in the text or in the wiring diagram... There is nothing attached on this car, but there is some wiring in the area - please see below: I have had a look at the cap to try to see some obvious metal connection points, but to be honest it is so grubby in that area it is difficult to see clearly.The Brown wire in the phot is connected at one end to the end of the master cylinder and the (larger) Black wire goes off through the bulkhead behind the washer fluid reservoir. Thanks in advance for any help or advice that you can provide. Quote Link to comment Share on other sites More sharing options...
wayne ingham Posted January 7, 2018 Share Posted January 7, 2018 (edited) This should have 2 separate wires going to the master clylinder cap one brown,one brown and white l do have a better photo but cannot load on here Edited January 7, 2018 by wayne ingham Quote Link to comment Share on other sites More sharing options...
IanMc Posted January 7, 2018 Author Share Posted January 7, 2018 Aha, thanks Wayne. I will DM you my E-mail address, perhaps you could send it there fore me? Thanks again. Quote Link to comment Share on other sites More sharing options...
wayne ingham Posted January 7, 2018 Share Posted January 7, 2018 I don’t know what a DM is l can post on Facebook if that helps,(not much good with this kink of stuff) Quote Link to comment Share on other sites More sharing options...
mantaray Posted January 7, 2018 Share Posted January 7, 2018 DM should be PM (personal message), Quote Link to comment Share on other sites More sharing options...
wayne ingham Posted January 7, 2018 Share Posted January 7, 2018 Ok l have a go at this Quote Link to comment Share on other sites More sharing options...
IanMc Posted January 7, 2018 Author Share Posted January 7, 2018 Thanks lads! Quote Link to comment Share on other sites More sharing options...
H-400 Posted January 7, 2018 Share Posted January 7, 2018 The cap of your reservoir looks one to have that switch, unscrew the cap and look if there is a floater hanging under your cap. That floater activates the switch to light the lamp on your dash, by the way: the same lamp is the hand-brake warning light! Quote Link to comment Share on other sites More sharing options...
IanMc Posted January 7, 2018 Author Share Posted January 7, 2018 4 hours ago, H-400 said: The cap of your reservoir looks one to have that switch, unscrew the cap and look if there is a floater hanging under your cap. That floater activates the switch to light the lamp on your dash, by the way: the same lamp is the hand-brake warning light! Great - many thanks Herman, much appreciated! Quote Link to comment Share on other sites More sharing options...
wayne ingham Posted January 13, 2018 Share Posted January 13, 2018 Have tried to do the computer thing l can’t work it out Quote Link to comment Share on other sites More sharing options...
IanMc Posted January 14, 2018 Author Share Posted January 14, 2018 6 hours ago, wayne ingham said: Have tried to do the computer thing l can’t work it out Hi Wayne, No problem at all, thanks for trying and sorry for causing you some stress. In actual fact I have managed to get the cap contacts repaired and the unit wired in now. Please take a look at my project thread for further details. Thanks again for all your help! Quote Link to comment Share on other sites More sharing options...
wayne ingham Posted January 14, 2018 Share Posted January 14, 2018 No worries.just know basics of computers ,no stress trying to learn a bit about computers lf I can help you at any time let me know 1 Quote Link to comment Share on other sites More sharing options...
