Red crust on blue antifreeze
hoobby
Seems to have caked somewhere and broke free,
nothing wrong with cake on your fingers!
Are you running a alloy engine, if oldschool cih, should you be running blue!
Was told, or knew blue for old, red for alloy, redtops, motorbikes etc!
Cih on blue antifreeze this stuff was sitting on the surface under the rad cap very probably the full lenght broke like thin ice did have green in there before (flushed) thought either rust or antifreeze mixing.car has sat for 4 months with new antifreeze will drain down,clean and flush.
Flush it out with water then refill with blue coolant, you should be fine. It'll just be a slight build up of corrosion from somewhere but its nowt to worry about. Ive been using blue coolant in alloy engines for years without issue..... but remember, dont mix blue and red coolant together, they dont like each other!
