Reversing light switch 4/5 speed same?
hoobby
Just finished working my way through an electrical nightmare of corroded connections took an hour to tease the headlight relay out of its block everything now works except the reversing lights tho I believe not required for a mot would like them to work switch shows open circuit all the time.was the same switch used for the 5 speed getrag boxes? Or is there anything inside the box that would cause this.
IMG_20190810_182529.thumb.jpg.0abf9aa1ac9ff9694534bbc7cdbe522c.jpg:D sorted :D...tho thread has a slightly smaller diameter just nipped in with a bit of rtv. Also for the hell of it tried to repair the old switch the act of pulling this apart nearly destroyed it cleaned up contact surfaces then utterly destroyed it trying to press it back together...oh well nothing ventured.....IMG_20190810_185130.thumb.jpg.7022b1758cca761fb70cb589691224f8.jpg
Edited by hoobby
Repair
