hoobby Posted July 24, 2020 Share Posted July 24, 2020 I may be having a dumb moment but what is the proper way to remove this type of connector. Quote Link to comment Share on other sites More sharing options...
Mike. Posted July 24, 2020 Share Posted July 24, 2020 (edited) Hi Hoobby, the injector loom terminates with 4 yellow plastic connectors that push on to the injectors, it really is just a wriggle side to side while pulling gently up that will release them. A word of caution, their location just above the exhaust manifold makes the Yellow plastic Brittle with the heat, so be careful not to snap or break them, if you do, all is not lost, Edelschmiede sell new ones that are easily changed by using a paper clip to push in a small tang and you can remove the old one and fit the new one. I had to do this on the Blue temp sensor plug, easy enough job. Edited July 24, 2020 by Mike. 1 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted July 24, 2020 Share Posted July 24, 2020 It is sometimes safer with older plugs to gently pry the retaining clip (metal) up on the sides and lift up a little, but it is not necessary to remove completely. 1 Quote Link to comment Share on other sites More sharing options...
hoobby Posted July 24, 2020 Author Share Posted July 24, 2020 Rocking and pulling the block that's the way I've been removing them just seems rough and crude 🐒. Quote Link to comment Share on other sites More sharing options...
