Jonathan Pounsett Posted January 1, 2021 Share Posted January 1, 2021 Does anyone have a rollover jig for sale or some plans so I can fabricate my own? Quote Link to comment Share on other sites More sharing options...
mantasrme Posted January 2, 2021 Share Posted January 2, 2021 I put up some dimensions of the 3 different ones i have in use currently at 2 Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted January 2, 2021 Author Share Posted January 2, 2021 Thanks David, I never thought to search “rotisserie” 🤦 I’ve measured up my garage now and I don’t actually have enough space - I’ll have to come up with another plan. Quote Link to comment Share on other sites More sharing options...
stumpy Posted January 2, 2021 Share Posted January 2, 2021 (edited) 9 hours ago, mantasrme said: I put up some dimensions of the 3 different ones i have in use currently at just an idea maybe worth putting the height on your roof beams in the garage so people know the minimum height required with the shotest pivot height spit dont know whats happened there i cant see the reply ,,,,,, but would it be an idea to add the height on you garage roof/beams so people know the minimim height can get away with on the lowestheight pivot spit ..... hope that makes sense Edited January 2, 2021 by stumpy Quote Link to comment Share on other sites More sharing options...
®evo03 Posted January 2, 2021 Share Posted January 2, 2021 They are quite deceptive, manta lifted is about 4ft of the ground at centre of front nose cone, car can do a full rotate, but it is tight, How im ever gonna get it down on my own! 1 Quote Link to comment Share on other sites More sharing options...
stumpy Posted January 2, 2021 Share Posted January 2, 2021 so youd need a minimum of say 6.ft 6 or there abouts head height Quote Link to comment Share on other sites More sharing options...
mantasrme Posted January 3, 2021 Share Posted January 3, 2021 18 hours ago, Jonathan Pounsett said: Thanks David, I never thought to search “rotisserie” 🤦 I’ve measured up my garage now and I don’t actually have enough space - I’ll have to come up with another plan. How high is your garage roof beams? you might be able to make one that lets you turn it onto its side but not fully over. Or make one on wheels and pul it outside to rotate then push back in upside down maybe? 17 hours ago, stumpy said: dont know whats happened there i cant see the reply ,,,,,, but would it be an idea to add the height on you garage roof/beams so people know the minimim height can get away with on the lowestheight pivot spit ..... hope that makes sense My garage that the first/lowest one was used in has 5'11" beams. But the pivot point of that one wasn't right as the shell was top heavy and didn't rotate easily. The pivot point wants to be offset from the mounting bar (like the 2nd jig i made) by about 3 or 4 inches from memory. So i think you could just about get it around in a 6'6" space, but you would need to get the pivot point spot on to stop it hitting the floor/roof. 1 Quote Link to comment Share on other sites More sharing options...
stumpy Posted January 3, 2021 Share Posted January 3, 2021 (edited) i beleive the lean to i knocked up is 6.6 at the lowest i have a spit here its a universal one just make a mounting bar to suit what your mounting it to but it has had a mk2 escort on it and theres quite a bit of spread in the feet so can drop it quite a bit just by spreading the legs further out i didnt build it i bought of a mate for 50 quid i think but itnow needs de rusting painting Edited January 3, 2021 by stumpy Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted January 3, 2021 Author Share Posted January 3, 2021 It’s tight but I’m alright for height. I don’t have enough length! 😂 1 Quote Link to comment Share on other sites More sharing options...
stumpy Posted January 3, 2021 Share Posted January 3, 2021 story of my life mate lol Quote Link to comment Share on other sites More sharing options...
®evo03 Posted January 4, 2021 Share Posted January 4, 2021 Car is bigger than the garage! Win win! Quote Link to comment Share on other sites More sharing options...
