Troubled Taff Posted May 4, 2021 Share Posted May 4, 2021 This is probably an easy one but how do I get the steering wheel off please? Where do the pullers go? Quote Link to comment Share on other sites More sharing options...
rutts Posted May 4, 2021 Share Posted May 4, 2021 Puller has two legs that go through the two holes in steering wheel boss. The pulled is around a tenner on eBay makes it an easy job not pulling your back out yanking on steering wheel. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted May 4, 2021 Share Posted May 4, 2021 usually they come off without a puller. never ever needed one in 30 years but theres always an exeption. usually i undo the nut to the last few threads then pulling/rocking the wheel at 9 o clock and 3 o clock works for me. the internal spring is assisting you too ! however if this doesnt work never ever be tempted to use a hammer or any shocks.you will possibly damage the collapsable section or the top bearing/ housing. Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted May 4, 2021 Share Posted May 4, 2021 I struggled to remove mine so removed the legs on a puller slipped it through and behind the wheel and tightened it onto the centre nut. Popped straight off. I also leave the nut on a few threads. Quote Link to comment Share on other sites More sharing options...
Troubled Taff Posted May 5, 2021 Author Share Posted May 5, 2021 Great advice thanks I'll try again on the weekend. Stay safe and thanks again. Quote Link to comment Share on other sites More sharing options...
