xe conversion
Greg w
On 30/12/2022 at 14:57, Paul Barrett said:
Yes you’ll need sump and pickup pipe. Retro power don’t have any left.
I believe I have a pickup pipe you’ll need
that would be great, how much would you want for it? thanks.
If you get to point that you can’t find one, then the escort one does work if you can be bothered to mod a little and the std XE pick-up pipe can be modded to fit too, if extended and braised
https://www.motorsport-tools.com/vauxhall-2-0-xe-red-top-16v-rwd-steel-big-wing-wide-sump-pan.html
Used one as basis for SAAB B204 sump setup
Edited by Jessopia74
9 hours ago, Greg w said:
i thought it was too deep at the front for an A.
what needs modding just cutting and lowering?
I can check the depth, but I am sure it’s not much different to the cast one.
Main thing is probably the slope to the sump, it’s very tight ti the xmember, but if you jiggle with engine mounts should work -or chop and weld.
  • 5 months later...
