cam.in.head Posted April 21, 2023 Share Posted April 21, 2023 hi. i recently posted for anyone who may have had any of the lower injector rubber seals. i managed to find a couple of suppliers from suggestions in replies but in both cases they have arrived totally wrong .ie the wrong size. one was from an injector specialist .the seals he sent were way too small. fitted on the end of the injector but not tall enough to begin to seal and smaller diameter too. then got some of ebay claiming to fit but were too big and had rounded corners ! all the ones ive had in the past have come in headgasket sets and been perfect. identical to the originals. i cannot add a reply to my original advert so has anyone got 4 they will sell or know where the correct ones can be got ? its the small lower ones that go over the yellow pintle and insert into the black mounting block.( but you probably know that !) cheers. Quote Link to comment Share on other sites More sharing options...
®evo03 Posted April 21, 2023 Share Posted April 21, 2023 Have you tried, https://www.mrinjectoruk.co.uk/collections/historic-injector-restoration Quote Link to comment Share on other sites More sharing options...
1200bandit Posted April 21, 2023 Share Posted April 21, 2023 I have some somewhere, was in my toolbox in work but have retired so they are somewhere in my garage,little workshop They are used ones but in good condition Will have a look tomorrow and let you know Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted April 21, 2023 Author Share Posted April 21, 2023 3 hours ago, ®evo03 said: Have you tried, https://www.mrinjectoruk.co.uk/collections/historic-injector-restoration yes but they send 14mm x4,4 mm ones which are too small. insisting they are the correct ones ! ours are more like 15.5mm x 5.5mm hopefully somebody will have some new ones they dont need. 3 hours ago, 1200bandit said: I have some somewhere, was in my toolbox in work but have retired so they are somewhere in my garage,little workshop They are used ones but in good condition Will have a look tomorrow and let you know thankyou for reading and reply but must be new . cheers Quote Link to comment Share on other sites More sharing options...
