Jonathan Posted June 14, 2023 Share Posted June 14, 2023 I’m looking to convert my rear brakes from drum brakes to discs. Was just wondering does anyone know where I can buy the conversion brackets to mount the callipers for a 4 stud. Also looking to buy a set of callipers discs and pads for 15” wheels. Quote Link to comment Share on other sites More sharing options...
Moonmonkey Posted June 14, 2023 Share Posted June 14, 2023 Have a look at this thread😊 There are also other options on EBay.de 1 Quote Link to comment Share on other sites More sharing options...
Jonathan Posted June 15, 2023 Author Share Posted June 15, 2023 10 hours ago, Moonmonkey said: Have a look at this thread😊 There are also other options on EBay.de Thanks a lot I’ll look into it 😁 Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted June 15, 2023 Share Posted June 15, 2023 If you were up to making your own brackets, you can use ford Granada Mk3 rear calipers and discs (re drilled to manta 4 stud) . If you fit them at about 10 to 12 position , you can use your manta handbrake cable. These are for Fords, you may be able to use the same brackets... 1 Quote Link to comment Share on other sites More sharing options...
paulmanta Posted June 15, 2023 Share Posted June 15, 2023 I will be at sywell with a full kit I removed fully working from a car I have here that I am putting back to standard. Nothing wrong with it but I want drums for the restoration ! 3 Quote Link to comment Share on other sites More sharing options...
Jonathan Posted June 15, 2023 Author Share Posted June 15, 2023 8 hours ago, GTEPETE said: If you were up to making your own brackets, you can use ford Granada Mk3 rear calipers and discs (re drilled to manta 4 stud) . If you fit them at about 10 to 12 position , you can use your manta handbrake cable. These are for Fords, you may be able to use the same brackets... Thanks for the info Pete I’ll have a look into that Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted June 16, 2023 Share Posted June 16, 2023 I’ve got Sierra rear calipers and mk3 escort front disks (probably the same as Granada rears) and they work pretty well. But Paul would be your best bet as he has a complete kit to start you off 😁 1 Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted June 18, 2023 Share Posted June 18, 2023 For ease of fitting, Paul's offer is a good one.. Quote Link to comment Share on other sites More sharing options...
