plumster Posted May 30 Share Posted May 30 Hi folks, my fanbelt has a bit too much play but the alternator is at the end of the bracket groove. Searched the old Haynes manual but I can't find the length a replacement should be. its a 1.6, not sure if there is a difference but any assistance greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 30 Share Posted May 30 You should be able to measure the length of your current one by going from Pulley center to center, use https://www.bearingboys.co.uk/MEASURE-A-BELT--22-a But I think they will have put the 1.8s belt on that is a bit longer than the CIH belt. (900 v 975mm) 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted May 30 Share Posted May 30 900 on one of mine 925 on another . ( depends a little on the crank pulley and water pump pulley types ) 1 Quote Link to comment Share on other sites More sharing options...
plumster Posted May 31 Author Share Posted May 31 Europarts keep a 10 x 935 in stock, I'll give that a go. Cheers. 1 Quote Link to comment Share on other sites More sharing options...
plumster Posted June 2 Author Share Posted June 2 Well... 935 is too long, I got a 900mm from local accessories shop & that does the job. 3 Quote Link to comment Share on other sites More sharing options...
