LostSoul Posted June 15 Share Posted June 15 Hi there I need to sort out my carb😐 Cold/cool starting is painful - auto choke is way too enthusiastic and floods the system until the engine has been running for quite a few seconds. There's lots of 'revving' involved to keep the engine running through that time... Engine and carb are factory original. Shall I just replace the carb like-for-like and stick with auto choke or is there a recognised 'fix' please? If the former, what do I order please? 🤓 All help gratefully received as always. Best wishes to all LS Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted June 15 Share Posted June 15 Can you convert it to manual choke? I prefer to be in control of the engines drinking problem myself. 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted June 16 Share Posted June 16 yes i would agree . you should be able to find a manual conversion on ebay also im pretty sure that the solex on the 1.6 is a similar size choke unit as the zenith so that may open up your options . worth making sure the existing choke is working ok and set up corrextly first as the original sydtem was pretty simple and reliable . but study a manual and get an undestandinv of it yourself as i doubt any garages will know how yo fo it unless you find an old mechanic ! Quote Link to comment Share on other sites More sharing options...
LostSoul Posted June 16 Author Share Posted June 16 Thank you for the replies. A specialist rebuilt the original carb when I got the car and warned that the auto choke can cause issues. Your comments here have made me decide to go down the manual choke route. I have taken the plunge and ordered a new manual-choke Weber carb kit for this car from Fast Road Cars on eBay... A Good move?? Thanks again LS 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted June 16 Share Posted June 16 2 hours ago, LostSoul said: Thank you for the replies. A specialist rebuilt the original carb when I got the car and warned that the auto choke can cause issues. Your comments here have made me decide to go down the manual choke route. I have taken the plunge and ordered a new manual-choke Weber carb kit for this car from Fast Road Cars on eBay... A Good move?? Thanks again LS Weber is a proven go to replacement. Certainly find more help/tuners that will setup a Weber rather than pull that usual face when mentioning others 😃 1 1 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted June 16 Share Posted June 16 You’ve done the right thing 👍 1 1 Quote Link to comment Share on other sites More sharing options...
