Auto To Manual
baldbrian
You will need:
Gearbox and mount - 5 speed from a GTE manual.
Flywheel - from 2.0L GTE manual.
GTE clutch.
Spigot bearing - dont think the autos have one installed?? Check the end of your crank when stripping it down.
Clutch cable to suit gearbox - later 5 speed cable. 1800 and 2.0L GTE use the same cable.
Pedal box for clutch pedal - Any manual b series manta or mk1 cavalier.
GTE manual propshaft - not sure if auto is the same??
5 speed manual centre console.
Probably missed a few items but i'm sure someone will come on to fill in the blanks......
You will need:
GTE clutch.
perfect snowy, you will need the spigot bearing definatly and the prop is longer on a manual. gear box tunnel top
You can use a 4 speed console as opposed to the 5 speed. Weld up the "Auto" hole and offer up the console, align the mounting holes and measure 34cm from rear of the console to the rear cross member( theres a hole right in the middle). Mark out and cut the tunnel then you can shorten the shift on a 5 speed and it goes straight in. Just an option. :mellow:
