the german Posted December 23, 2009 Share Posted December 23, 2009 just doing a job on the mates manta . does anyone have the valve clearance for a 88 2.0 gte ? she,s just not runing that sweet . Quote Link to comment Share on other sites More sharing options...
manta400john Posted December 23, 2009 Share Posted December 23, 2009 just doing a job on the mates manta . does anyone have the valve clearance for a 88 2.0 gte ? she,s just not runing that sweet . Unless someones changed them the GTE has hydraulic tappits. John. Quote Link to comment Share on other sites More sharing options...
the german Posted December 23, 2009 Author Share Posted December 23, 2009 thanks for putting me straight on that . . . . . . . . any common falut,s to look for? Quote Link to comment Share on other sites More sharing options...
manta400john Posted December 23, 2009 Share Posted December 23, 2009 What running issues does it have?? Quote Link to comment Share on other sites More sharing options...
Snowy Posted December 24, 2009 Share Posted December 24, 2009 Even on a GTE with hydraulic tappets they still need setting. If they are not set correctly you will get running issues. Generally someone would have had to have played with them. But it's still worth checking. Do you have a Haynes manual?? Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted December 24, 2009 Share Posted December 24, 2009 as people have said above gte models have hydraulic tappets which maintain correct clearance PROVIDING that they are working correctly & adjusted correctly. working on one cyl at a time.turn engine with spanner till valve 2 is fully open.then back off adjuster on arm 1.the tappet should begin to expand until its reached its full length (you can see the inner coming out,until it reaches the retaining cap)if the tapped doesnt expand properly then its either fully or partially seized.(or had been adjusted incorrect to start with & was already fully out)remove,dismantle,clean,reassemble,refit .a worthwhile job in any case if any doubt. assuming all is now well.adjust arm down until tappet is JUST CLEARANCE FREE.then one turn down from this setting. rocker arm should settle down & have some movement again after a few minutes or so. repeat for other 7 valves.(one valve open,adjust other cylinders valve) job done ! Quote Link to comment Share on other sites More sharing options...
