G1ROSS1 Posted March 1, 2010 Share Posted March 1, 2010 Can anyone tell me if the outer rim on the gte exclusive alloys is meant to be polished or just painted? i know the centre of them is finished in anthracite, has anyone got an exact paint code for this? also an exact paint code for the standard silver? thx. Quote Link to comment Share on other sites More sharing options...
manta400john Posted March 1, 2010 Share Posted March 1, 2010 Can anyone tell me if the outer rim on the gte exclusive alloys is meant to be polished or just painted? i know the centre of them is finished in anthracite, has anyone got an exact paint code for this? also an exact paint code for the standard silver? thx. Painted but don't know the exact colour......but someone will John. Quote Link to comment Share on other sites More sharing options...
misterconyers Posted March 1, 2010 Share Posted March 1, 2010 The silver rim is sprayed on over the anthracite on the originals. I couldn't tell you the paint codes but I found that BMW StahlGrau ( Steel Grey) metallic was a very good match for the anthracite with the added advantage of having a nicer 'shimmery' effect in the sun ! I think I used a Ford colour for the silver . . Cheers, Tim Quote Link to comment Share on other sites More sharing options...
G1ROSS1 Posted March 2, 2010 Author Share Posted March 2, 2010 (edited) Can anyone else shed any light on the matter? Looks similar misterconyers, did you spray them yourself? Been quoted about £55 for a wheel, this sound about right? Just after finding the following, would this be the same colour as used on the wheels? My cars 1988 but there no other code for anthracite so...... VAUXHALL ANTHRACITE 81L 1980 1987 METALLIC Edited March 2, 2010 by G1ROSS1 Quote Link to comment Share on other sites More sharing options...
czwh42 Posted March 3, 2010 Share Posted March 3, 2010 Can anyone else shed any light on the matter? Looks similar misterconyers, did you spray them yourself? Been quoted about £55 for a wheel, this sound about right? Just after finding the following, would this be the same colour as used on the wheels? My cars 1988 but there no other code for anthracite so...... VAUXHALL ANTHRACITE 81L 1980 1987 METALLIC I think 81L is a generic colour because my Calibra Turbo was 266 / 81L which was Diamond Black. I believe the athracite colour code you are after is 107 / 81L. Make sure it is the colour before you buy though as no guarantee is given I thought I had a can of it, but I can't find it at the moment. As for the silver, any decent bright silver will do the job. Quote Link to comment Share on other sites More sharing options...
Mrbus Posted March 5, 2010 Share Posted March 5, 2010 The silver rim is sprayed on over the anthracite on the originals. I couldn't tell you the paint codes but I found that BMW StahlGrau ( Steel Grey) metallic was a very good match for the anthracite with the added advantage of having a nicer 'shimmery' effect in the sun ! I think I used a Ford colour for the silver . . What tyre size is this please? Is it 205 40 17? Cheers, Tim Quote Link to comment Share on other sites More sharing options...
G1ROSS1 Posted March 25, 2010 Author Share Posted March 25, 2010 (edited) Wheels now sprayed, just need the tyes. Were the orginal tyes on these uniroyal rally 195 60 hr14? Are these still available? Edited March 25, 2010 by G1ROSS1 Quote Link to comment Share on other sites More sharing options...
Mrbus Posted March 25, 2010 Share Posted March 25, 2010 You wont get hold of them anymore. Tyres only have a shelf life of 5 years as the rubber loses all of its suppleness & tends to go hard. Will last a lot longer though but your grip side of things will not be very good. Quote Link to comment Share on other sites More sharing options...
G1ROSS1 Posted March 25, 2010 Author Share Posted March 25, 2010 Can anyone suggest a good tyre in around the same price? (£50) Or would you just stick with uniroyal and go for the rainsport? Can you put a lower profile on also? I know nothing about tyres as im sure u've guessed. Quote Link to comment Share on other sites More sharing options...
misterconyers Posted March 25, 2010 Share Posted March 25, 2010 (edited) Mrbus - The tyres in the pic are 205 35 17s I think, cheapy ones that were on the wheels when I got them, will get some better ones when its back one the road, probably the same size. On the subject of tyres, rainsports are good just hard to find these days, for a 195 60 14 a good tyre for around £50 are Falken 912's in my experience, much better than the older models which used to wear out after 5-6k Edited March 25, 2010 by misterconyers Quote Link to comment Share on other sites More sharing options...
keith1200 Posted March 25, 2010 Share Posted March 25, 2010 I would suggest 195/60/14 Tigra tyres, (depending on your mileage) about £20-£25 each. An unbrand tyre made in Serbian (i think) by a very big Germany tyre firm that starts with a 'C' cheap rubber oops mixed with silicon! but a good engineered tyre, I.E it wot break-up under pressure like the 'cheap and nasty' asian crap. There is a malaysian factory that make 'ok-ish' tyre, back by a small japanese tyre firm, can't remember their name Quote Link to comment Share on other sites More sharing options...
Mrbus Posted March 25, 2010 Share Posted March 25, 2010 I would suggest 195/60/14 Tigra tyres, (depending on your mileage) about £20-£25 each. An unbrand tyre made in Serbian (i think) by a very big Germany tyre firm that starts with a 'C' cheap rubber oops mixed with silicon! but a good engineered tyre, I.E it wot break-up under pressure like the 'cheap and nasty' asian crap. There is a malaysian factory that make 'ok-ish' tyre, back by a small japanese tyre firm, can't remember their name Tigra is a budget tyre. They exactly the same as autogrips. Falkens are a lil bit better but for £50 you can get a decent tyre starting from firestones, goodyears, pirelli. Best ones i would have is the goodyear nct5 (1 shown further up) Depends if you mean £50 each or all 4, which in that case you might get some partworns or remoulds if you want to sink that low lol Quote Link to comment Share on other sites More sharing options...
keith1200 Posted March 25, 2010 Share Posted March 25, 2010 (edited) [edit] yeah good educated advice there nevermind that I work for a major tyre company In future? i promise never to reply in the free section, to migwag users. Edited March 25, 2010 by keith1200 Quote Link to comment Share on other sites More sharing options...
G1ROSS1 Posted March 26, 2010 Author Share Posted March 26, 2010 (edited) £50 to £60 for each tyre roughly. Can get uniroyal rainsport for £50, was just wondering if there was anything else about. My other options http://www.tyretraders.com/tyresearchresults.aspx?width=195&ratio=60&rim=14&man=All&flat=False&filter=Price&ftype=Ascending&pricing=1&cat=All Edited March 26, 2010 by G1ROSS1 Quote Link to comment Share on other sites More sharing options...
Mrbus Posted March 27, 2010 Share Posted March 27, 2010 [edit] yeah good educated advice there nevermind that I work for a major tyre company In future? i promise never to reply in the free section, to migwag users. Same as I for the last 11 years so that makes both of us. So no need to think highly of yourself as your just the same as everyone else. No need to get sarcy about it as im just trying to help people as i have had help from other users. Have a nice day! ;-) £50 to £60 for each tyre roughly. Can get uniroyal rainsport for £50, was just wondering if there was anything else about. My other options http://www.tyretrade...icing=1&cat=All Have you tried blackcircles.com or .co.uk? Quote Link to comment Share on other sites More sharing options...
astra-sxi Posted April 6, 2010 Share Posted April 6, 2010 Have you looked at Camskill for tyres? Some really good prices on there. For 195/60R14's you can get then from £28.10 - £51.29. Have a look here. Quote Link to comment Share on other sites More sharing options...
