cam.in.head Posted January 11, 2011 Share Posted January 11, 2011 after reading from a member about his problems with water in his bellhousing has he uncovered a major mod we could all fit to our cars or would it not work.. a system of pumping air into your chassis or sills etc from a low volume pump to provide an airflow through these areas..this like it does in an house would stop condensation.. hmmm .got me thinking now. cheers mr suzuki ! Quote Link to comment Share on other sites More sharing options...
Retro Power Posted January 16, 2011 Share Posted January 16, 2011 air will be flowing through it anyway. the reason for rot is the double skinned areas, plus no paint in there Quote Link to comment Share on other sites More sharing options...
Christ Posted January 16, 2011 Share Posted January 16, 2011 and doesn't air promote rust anyway if you're going to install such a system best off pumping rust proofing stuff in there instead of air Quote Link to comment Share on other sites More sharing options...
garymanc Posted January 16, 2011 Share Posted January 16, 2011 just keep a few off these in yor car http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_169605_langId_-1_categoryId_165745 Quote Link to comment Share on other sites More sharing options...
pat Posted January 16, 2011 Share Posted January 16, 2011 reroute the breather pipe from the rocker cover , the more tired the engine is the less rusty the car is? Quote Link to comment Share on other sites More sharing options...
mantadoc Posted January 16, 2011 Share Posted January 16, 2011 after reading from a member about his problems with water in his bellhousing has he uncovered a major mod we could all fit to our cars or would it not work.. a system of pumping air into your chassis or sills etc from a low volume pump to provide an airflow through these areas..this like it does in an house would stop condensation.. hmmm .got me thinking now. cheers mr suzuki ! Rig up another pump................ one with waxoyl Or save up till you have 30 litres of old engine oil, put duck tape over the sill drain holes. Gutter under sills back to tub and fill your sills with oil then let it drainz out by pulling the tape off the holes Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted January 17, 2011 Author Share Posted January 17, 2011 when i fitted new sills many years back i covered all the drain holes & then bought a few big tins of paint & filled the sills up via the seatbelt holes i think. then unbunged the drains & caught the paint. i remember it took about 2 days to drain out but i knew everything was well painted up in there ! intend to do the same with chassis after ive replaced any previous repairs to a much higher standard & maybee filled up with deox for a week or so. .just thought the airflow idea seemed a good idea. also feeding the crank vent would be a good idea except makes the car a bit smelly to follow ! prob illegal anyway.. may just deox & rinse... paint & drain... oil & drain.. maybee repeating oil every couple of years or so. Quote Link to comment Share on other sites More sharing options...
