Widebody V8 Manta
steel
  • Replies 96
  • Created
  • Last Reply
Top Posters In This Topic
new chassis rails or will be? out of 60x 40 box section as per retropowers turbo manta build ...the boss has said i have to plaster the hallway today so no manta fun :(...cost £30 including fuel to go and get it
Edited by steel
made a start today cut the first 2 pieces of each rail with the i think correct angles , made the sleeves/crush tubes that will be fitted in the rails where the bolts for the crossmember go through and drilled the 22mm holes in the rails to accept them will sort pics l8er :thumbup
another 2 pieces and 4 cuts for each rail and i can start tacking them together
also got some 1 inch box section cut to length that will be used to brace the car before i start cutting out the original rails and to hold the crossmember in place to keep alignement of the rails
Edited by steel
now that would be handy i do like the reinforcing plates you fitted B) and ime just copying what you guys did, at least that way i know it will be up to scratch if its good enough for you its good enough for me :thumbup
Edited by steel
tubes all mitre cut to correct angles and length tho ive purposely left the front rail that runs along inner wing/eng bay longer than needed to be trimmed to length l8er
big thanks to retropower for the help via pm :thumbup
Edited by steel
managed to track down a used but mint fibreglass 400 bonnet and a 1 piece fibreglass bootlid with built in exclusive/400 spoiler and quarter panel corner pieces no losing shape and snapping mounting bolts on this and should help keep weight down
Edited by steel
ok sod the rain braved the weather and went out put the rear wheels on ramps and supported the front of the car up of the floor so i can get to the old rails to cut them off,, and i also stripped the front crossmember down so it was bare with just the rear arms attached that bolt to the chassis rails that was a nightmare 1 of the bolts came out easily enough the d/s however was seized solid ended up cutting the head off the bolt with all the other bolts holding the crossmember undone/removed it fell out,,i stripped ithe hubs ect from while off the car then refitted the bare unit ime now ready to start bracing the car
Edited by steel
got up today welded in some braces in the engine bay to support the crossmember in place and hopefully keep the mounting points in place while i remove the old rails
http://img857.images...1834/brace3.jpg
http://img850.images...3924/brace1.jpg
http://img580.images...1065/brace2.jpg
if anybody sees anywhere else i should put a crosspiece or gusset feel free to say so :thumbup
ime thinking maybe a short pieces from the rear of each down tube going to rear leg to the bulkhead it will stop any back fourth movement????
Edited by steel
welded the crush tubes in place after weld prepping them chamfered the edge of the crush tubes and countersunk all the holes so the weld had a decent bed to flow into means i can smooth the welds on the inside face of the rails where the crossmember sits without losing strength the longer sections are to go in the eng bay for the crossmember bolts to go through and will be smoothed both sides for a flush fit trying to get 30mins work on the manta here and there in between day to day work, training ect
http://img198.images...crushtubes1.jpg
http://img808.images...crushtubes3.jpg
http://img571.images...crushtubes2.jpg
Edited by steel
