mantapaperman Posted May 6, 2011 Share Posted May 6, 2011 (edited) hi all..can anyone confirm if it is possible to remove the crossmember braces that go to the swan necks whilst the engine is in? were on a gte with the redtop/ 1.8 sump fitted,and the inner bolt that goes thru crossmember and holds steering rack on looks like the bolt will not come out cos of the wing on the sump? haqs anyone done it? i've just poly bushed some new susp components and those braces too,and i am goin to attempt the swap over!! but probly wont bother with the brace if its a nacker to get off..anyway thanks in advance.. Edited May 12, 2011 by mantapaperman Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 6, 2011 Share Posted May 6, 2011 If I've read this correct, you want to remove the front axle without removing the engine ja? Possible, but you will have to support the engine and gearbox in the car and remove engine mounts off engine. Hope this helps. Quote Link to comment Share on other sites More sharing options...
mantapaperman Posted May 6, 2011 Author Share Posted May 6, 2011 thanks sutty was just changing the top and bottom wishbones and leaving crossmember in situ? but the legs that go to swan necks are crusty also...i dont think the inner bolt will come out past sump? will have a go..ta again Quote Link to comment Share on other sites More sharing options...
manta88 Posted May 6, 2011 Share Posted May 6, 2011 You will have to remove the exhaust manifold and undo the engine mounts then lift the engine to get the bolts out as they will hit the sump, did this on my car it was abit difficult. Quote Link to comment Share on other sites More sharing options...
eldoradoCoupe Posted May 6, 2011 Share Posted May 6, 2011 Those bolts through the swan neck are likely rusted solid so probably not wise to do it with engine in situ as you'll prob need grinder access, Unless you've a 4 poster - that would help! Quote Link to comment Share on other sites More sharing options...
stradacab Posted May 6, 2011 Share Posted May 6, 2011 Second what manta88 said. The arms can be removed to improve access to the legs for repair. In the 1800 version you will have to undo the engine mounts and jack the engine up so you can take those long 17mm headed bolts all the way out. Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 6, 2011 Share Posted May 6, 2011 Ahhh I see now. Those chassis bolts are a right pain in the sphincter. Quote Link to comment Share on other sites More sharing options...
mantapaperman Posted May 8, 2011 Author Share Posted May 8, 2011 thanks again for the info chaps..now sorted..length of wood over shock mounts to hold engine up and lowered the crossmember a tad..what a b***h of a job! the bottom arms are abit fiddly to refit into member aswell. i was begining to think i'd bent something ..thanks Quote Link to comment Share on other sites More sharing options...
