Foolishness - Large Puddle
Robert1234
Essentially I was driving out of the uni car park and went through a large puddle a bit too quickly, car cut out around 3 seconds later. After 30 seconds of waiting I tried to start it, it fired up and I got about 75m down the road then it cut out at the island and is refusing to start. It does turn over though.
Any help would be appreciated.
Thanks
Rob
Check it's not full of water
Check the positive Red lead on the back of the dizzy isn't causing an arc to voltage to ground on the dizzy
Check the LT ignition under the coil by pulling back the large rubber cover on the ignition amplifier, make sure it's dry too
