peter evans Posted October 10, 2012 Share Posted October 10, 2012 looking for a red top set up for my manta project im in need of all parts to complete anyone help cash waiting Link to comment Share on other sites More sharing options...
rutts Posted October 10, 2012 Share Posted October 10, 2012 kev abbott with turbo conversion ? £1700 ono if still got it that is everything. parts for sale section. Link to comment Share on other sites More sharing options...
Kevin Abbott Posted October 11, 2012 Share Posted October 11, 2012 With a bit of luck that's all going on Sunday I've no sumps, boxes or mounts left now, most of my XE stuff will be gone soon Link to comment Share on other sites More sharing options...
HMTurbo Posted October 11, 2012 Share Posted October 11, 2012 I have engine mounts here Link to comment Share on other sites More sharing options...
bones Posted October 12, 2012 Share Posted October 12, 2012 I have an XE exhaust manifold to suit 0 deg engine installation and Inlet to suit 45's. Link to comment Share on other sites More sharing options...
TJM Posted October 12, 2012 Share Posted October 12, 2012 (edited) Hello Let me check tomorrow, but I have an engine (will need strip and check/rebuild, even though a good runner when taken out the Astra Mk2 GTE 16V has been sat for a number of years) and think I have the following: 1800 Sump (Secondhand), with pickup pipe and dipstick 7 Degree inlet manifold (NOS) 7 degree type 9 bellhousing (with bolts) (NOS) XE chassis mounting kit (NOS) or Manta 1800 mounts. Engine mount bobbins (38 mm thickness) jenvey throttle bodies (Secondhand) Can supply new Ashley 4-2-1 Manifold if required. Once I know what I have got I will put a price on it. Regards Tim Edited October 12, 2012 by TJM Link to comment Share on other sites More sharing options...
peter evans Posted October 12, 2012 Author Share Posted October 12, 2012 hi tim thanks for that im very interested i was with you earlier this year i was looking for a manta bias set up so let me know what you have and ill pop down to see you thanks again peter i also need 3 feed pipes from the resivoir pots to the pedle box 7/16 unf do you stock them? peter Link to comment Share on other sites More sharing options...
TJM Posted October 12, 2012 Share Posted October 12, 2012 Hello Peter I also have feed pipes in stock. Regards Tim Link to comment Share on other sites More sharing options...
peter evans Posted October 12, 2012 Author Share Posted October 12, 2012 k ill call down for some how long are they and cost please tim regards peter 1 Link to comment Share on other sites More sharing options...
peter evans Posted October 13, 2012 Author Share Posted October 13, 2012 if you take paypal ill pay for them and maybe you can post them to me ? thanks peter Link to comment Share on other sites More sharing options...
TJM Posted October 15, 2012 Share Posted October 15, 2012 (edited) Hello Peter The drop links are 310mm in length, price £15.00 each. P&P £5.25 by Royal Mail. I can accept PayPal at no extra charge. FYI I have the following XE bits: Engine £300.00 1800 Manta Sump, pick up pipe, dipstick £200.00 7 degree SBD inlet manifold (jacketed) with water pipe connection £125.00 7 degree SBD bellhousing £150.00 bellhousing to block and gearbox cap head bolts £15.00 1800 Manta engine mounts (1 has been modified) £20.00 38 high engine bobbins £10.00 a pair XE Chassis mounting kit £55.00 Cheers Tim Edited October 15, 2012 by TJM Link to comment Share on other sites More sharing options...
peter evans Posted October 15, 2012 Author Share Posted October 15, 2012 hi tim 1) as far as the engine goes does it need rebuild or is it ready to fit ? 2) the other thing is ive got a fluid clutch how do i get round this as the 1800 manta box is a cable type? but very interested in buying from you thanks peter Link to comment Share on other sites More sharing options...
TJM Posted October 16, 2012 Share Posted October 16, 2012 Hello Peter I would advise a rebuild as it has been sat for sometime. Clutch wise, you could make a bracket and mount a slave cylinder (http://www.ebay.co.uk/sch/i.html?_nkw=rover+clutch+slave+cylinder) to actuate the arm or even adapt a hydraulic release bearing such as Saab, Mondeo etc. Regards Tim Link to comment Share on other sites More sharing options...
