Wiring Loom Wrap
611
Thanks for the info, the loom is still in the car (the only bit i wont have removed on it :-) and i didnt want to have to take it out, so just wondered if i could get something to just wrap wround it in place?
Andy
I use convoluted tubing with a split down the side, easy to fit over the wiring in situ and the wiring can be accessed through the split if you need to test/replace/add a wire.
Available in all sorts of sizes and you can even buy different junctions for joining the runs together or just use insulation tape.
Also it can be removed and reused,
As the title suggest, anyone got any advice on the best stuff to use on the wiring loom?
Last time i used that plastic spiral stuff, but find it very stiff and not that flexible.
I found this while googleing: http://www.cablecraft.co.uk/protect/cable-sleeving-protection/wrappasleeve.html
any thoughts?
Andy
That looks like some decent cable care equipment. Might have to purchase some myself :)
