davo Posted December 30, 2012 Share Posted December 30, 2012 Hi I've got the carbs and I got the engine just need an inlet manifold to suit if anyone has one. Would also consider carb and manifold package as I can use my carbs elsewhere. Cheers Link to comment Share on other sites More sharing options...
MB15 Posted December 30, 2012 Share Posted December 30, 2012 Think people in the past have used a boog brothers inlet? (spelling) Think this is the link but others on here will keep you right - http://www.boggbros.co.uk/index.html Link to comment Share on other sites More sharing options...
lepo5 Posted December 31, 2012 Share Posted December 31, 2012 as kev says above, boog brothers is the best bet. Link to comment Share on other sites More sharing options...
mantasrme Posted December 31, 2012 Share Posted December 31, 2012 If you want a cheaper alternative you can chop down a standard xe inlet manifold. A bit of porting to the end, block the injector holes and its ready. But you will need to space the carbs apart to match the ports. Which is easier with some carbs than others. The advantage of spacing the carbs is that you can have a shorter manifold, which keeps the carbs nearer the engine and leaves more room for other things. Link to comment Share on other sites More sharing options...
