Rob36 Posted February 9, 2013 Share Posted February 9, 2013 Hi all. The rad in my recently aquired Mk1 Cav 1900 Coupe looks past its best. Its holding water fine, but the fins are in a bit of a state and its probably not as efficient as it once was! At first look, prices for a replacement rad look pretty dear, so Im weighing up my options. Ive heard that early Carlton rads are the same and go straight in. Is this accurate? Quote Link to comment Share on other sites More sharing options...
MANTAMAN Posted February 9, 2013 Share Posted February 9, 2013 Think the rads are about the same size but i'm sure the mounting brackets are in different positions, anyone with a MK 1 Carlton Rad who can check? Quote Link to comment Share on other sites More sharing options...
mantadoc Posted February 9, 2013 Share Posted February 9, 2013 What he said. Straps and bottom need swapping Quote Link to comment Share on other sites More sharing options...
bris jas Posted February 9, 2013 Share Posted February 9, 2013 Just had my rad checked over, but all ok although the guy quoted me around £130.00 to put a 3 core in if he found it to be knackered. Seemed like a decent guy and very reliable, if you want his number pm me Quote Link to comment Share on other sites More sharing options...
mantadoc Posted February 9, 2013 Share Posted February 9, 2013 I've never paid more than 70 for a recore 3 row, if not heavily modified engine, is a lot of money for no benefit Quote Link to comment Share on other sites More sharing options...
bris jas Posted February 10, 2013 Share Posted February 10, 2013 Its cooling a 4.0 V8 which was running a little hot. Quote Link to comment Share on other sites More sharing options...
Rob36 Posted February 10, 2013 Author Share Posted February 10, 2013 What he said. Straps and bottom need swapping Hmm. Someone suggested that there was a supporting pin at the bottom of the Carlton rad that you could run a die down so you can bolt it to the bottom mount like the standard one. So the whole bottom needs swapping? Never pulled a rad apart before! Sounds messy? I can get a cheap carlton rad y'see. Quote Link to comment Share on other sites More sharing options...
mantadoc Posted February 10, 2013 Share Posted February 10, 2013 The straps unsolder of the sides of the top tank and off the bottom tank. If you a tap into the captive nut at the bottom you puncture the bottom tank. Quote Link to comment Share on other sites More sharing options...
Exclusive Opel Posted February 10, 2013 Share Posted February 10, 2013 I have a Carlton rad in my Manta. Didn't bother swapping the frames around. Yes, run a die down the bottom pin. The side one's were just cut off. I then made a pair of shallow U shaped brackets for the side supports and literally just bolted them on where they would be on a Manta one. Should have some pics somewhere but not at home at the mo to look. 1 Quote Link to comment Share on other sites More sharing options...
Rob36 Posted February 10, 2013 Author Share Posted February 10, 2013 Yeah pics would be helpful ta! Quote Link to comment Share on other sites More sharing options...
Rob36 Posted February 12, 2013 Author Share Posted February 12, 2013 Well I decided to gamble on the Carlton rad. Its new old stock - £28 including postage, so if I can successfully modify it to fit, should represent a bargain! Quote Link to comment Share on other sites More sharing options...
