Very Nice Adjustable Thermostat Solution
611
Just thought i would post this as i have been searching for a while to find a nice solution for an adjustable thermostat so i could get rid of the kenlow cooker type as i never was happy with the way it looked. And i came across this one from Revotec http://www.revotec.com
They do a few different options but this one worked out just right as the to hose that i got from JS performance was from the B series setup and i new it would need extending ;-)
Only ever seen them fitted to the top hose. Thats what revotec and kenlow show on their fitting instrustions. Which i presume is to do with the fact that the engine thermostat will be open as the water needs cooling so the temp sensor will pick up that the water is too hot and put the fan on to cool the water going into the engine?
Im sure someone will know why?
I have similar kind of thermostat and have it in the top hose. Thats what the instructions said, and seems to keep the engine at the right temp no probs (when the bloody thing runs that is.......)
I took the cardboard off the radiator to help cool it tho :P
Hey Shug, how is the manta?
The cardboard is for running in very cold conditions, gives the engine more warmth. Just need to stop and remove it when the sun come out :-)
Bit like F1 when they tape up the ducts to get more heat in the brakes!!!!
Are you still running those bike carbs?
Dont think mine will get a respray for a while when i do get it back on the road. Im going to have a go at vinyl wrapping it and see how that works out, as its so much cheaper and looks good. But first got to finish putting the engine back together and work out the injection system :-)
I've always fitted the sensors/switch to the bottom pipe.
When the thermostat opens it lets hot water out of the engine into the top of the radiator, and pushes cool water thats in the radiator back into the engine.
The radiator will cool the water running through it if the car is moving through the air.
You only need the fan to kick in when the water returning from the radiator isn't being cooled enough by the radiator, so normally when the car is stationary, or being worked very hard
If you have it in the top hose the car probably won't overheat, but the fan will be running a lot more than it needs to and if anything you'll be overcooling the water in the radiator which can cause issues.
Also the top hose is not normally full of water and the sensors don't work if they're not submerged.
