eurocamper1 Posted April 21, 2013 Share Posted April 21, 2013 When i have my car up on jacks and let the rear suspension hang down the springs are loose and can be taken out. Is this normal The springs were installed but previous owner they were to lower 40mm but he may have cut them more The car sits very low Whats a good quality 40 mm lowering springs Thanks Henrik Quote Link to comment Share on other sites More sharing options...
mickappy Posted April 22, 2013 Share Posted April 22, 2013 yep normal with lowering springs. Quote Link to comment Share on other sites More sharing options...
upk Posted April 22, 2013 Share Posted April 22, 2013 That also answers my question then. I take it there's no problems encountered loosing a spring during driving then? Quote Link to comment Share on other sites More sharing options...
mickappy Posted April 22, 2013 Share Posted April 22, 2013 only if u get some air:-) 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted April 24, 2013 Share Posted April 24, 2013 i cannot see that being ok. any lowering by that amount will result in the shocks bottoming out. i would have thought shorter shocks should be fitted. either way a spring cannot be alowed to be loose on full travel. plus pan rod may hold axle at wrong place now? Quote Link to comment Share on other sites More sharing options...
opelman Posted April 26, 2013 Share Posted April 26, 2013 I hate to dampen anyones enthusiasm but having having experimented with many different springs on the track I came to the conclusion that its best to maintain a standard ride height at the rear otherwise the geometry goes out (and the exhaust gets in the way). To lower the rear the torque tube housing requires modification to ensure the axle maintains correct alignment and an adjustable panhard rod is required. However, if you are wanting to lower the rear just for the look of it then I suspect no great harm will be done. Quote Link to comment Share on other sites More sharing options...
eurocamper1 Posted April 27, 2013 Author Share Posted April 27, 2013 yes i see what is a good standard heigth rear spring to go shopping for and is it ok the front is lowered or what kinda srping should i run up front Quote Link to comment Share on other sites More sharing options...
daverwd Posted April 28, 2013 Share Posted April 28, 2013 I have lowered the front of my manta 400R with 30mm lowering springs & left the rears as standard.. have to say the cars sits & handles nice .. However it is used just for road use .. no idea how it would behave for track use.. Quote Link to comment Share on other sites More sharing options...
opelman Posted April 28, 2013 Share Posted April 28, 2013 I run 650lbs linear front springs lowered by about 30mm, I tried 400lbs but they were not really much different from standard. At the rear I run standard height 200lbs linear. Quote Link to comment Share on other sites More sharing options...
