TJM Posted April 29, 2013 Share Posted April 29, 2013 Hello For the ultimate brake kit I have developed an AP Racing kit with: 304x28mm front discs Pro5000+ Calipers Alloy Bells Alloy mounting brackets DS3000 Brake PAds Mounting hardware £1415 plus £22.50 P&P to UK Mainland. Designed to fit inside a Compomotive (or similar) 7x15 ET24 motorsport wheel. Regards Tim 1 Quote Link to comment Share on other sites More sharing options...
opelscott22 Posted April 29, 2013 Share Posted April 29, 2013 Ooooh shiny!! Are those calipers for road use? i.e, proper dust seals? Will they fit under 15" revo's? Im interested... Scott. Quote Link to comment Share on other sites More sharing options...
TJM Posted April 29, 2013 Author Share Posted April 29, 2013 Hello Scott These are racing calipers (no dust seals) but are available with stainless steel pistons as an optional extra. As for fitting under 15" revos I would have thought so but please compare internal dimensions and offsets. Regards Tim Quote Link to comment Share on other sites More sharing options...
jasper Posted April 29, 2013 Share Posted April 29, 2013 Hi Tim, can you supply the caliper mounting brackets seperately,if so how much. Regards Colin Quote Link to comment Share on other sites More sharing options...
mantaray Posted April 29, 2013 Share Posted April 29, 2013 For a road car you would need to use Cp5200 calipers which should be a direct replacement for the pro 5000+ ones. I think I still have a pair of used CP 5200 calipiers if you are interested. Quote Link to comment Share on other sites More sharing options...
TJM Posted April 29, 2013 Author Share Posted April 29, 2013 Hello I can supply the brackets and bells seperate if required. Bells £50 each anodised silver. Brackets £50 each anodised silver. P&P £11.50 to UK Mainland. In stock and ready for immediate despatch. Regards Tim Quote Link to comment Share on other sites More sharing options...
TJM Posted April 30, 2013 Author Share Posted April 30, 2013 Hello Reference using the CP5200 calipers they would need a new bracket as they have different mounting hole sizes (10mm as opposed to 12mm) and a small variation in mounting offset. These would however come with dust seals. I can make new brackets if required. Let me know. (Price would be the same). Regards Tim Quote Link to comment Share on other sites More sharing options...
TJM Posted May 7, 2013 Author Share Posted May 7, 2013 Hello to all I am just in the process of making new brackets so a road kit will be available soon using the CP5200 brake calipers (with brake seals). Regards Tim Quote Link to comment Share on other sites More sharing options...
TJM Posted June 19, 2013 Author Share Posted June 19, 2013 Hello Price of road kit £1475.00. Regards Tim Quote Link to comment Share on other sites More sharing options...
611 Posted June 19, 2013 Share Posted June 19, 2013 (edited) Hi Tim Do you have measurements for the mounting brackets? Im running some wilwood 4 pots on my A series and need to get some brackets and just wondered how different the AP setup is to the wilwood? http://www.theopelproject.com/?p=364 smaller calipers but i wonder how far off the setup in mounting holes is between the 2? Andy Edited June 19, 2013 by 611 Quote Link to comment Share on other sites More sharing options...
TJM Posted June 20, 2013 Author Share Posted June 20, 2013 Hello Are the calipers radial mounted, do you have a link to the caliper so I can get some specs. Mine are radial and 152mm mounting centres. Regards Tim Quote Link to comment Share on other sites More sharing options...
611 Posted June 20, 2013 Share Posted June 20, 2013 Hi Tim I didnt realise the AP's were radial mount. i didnt notice when i looked at the pictures. mine are tob mount (http://www.wilwood.com/Images/Caliper/Caliper_Photos-Large/Billet_Dynalite_SI-lg.jpg), so probably wont be any good for mine. Andy Quote Link to comment Share on other sites More sharing options...
Retro Power Posted June 21, 2013 Share Posted June 21, 2013 very good price that kit. Re. road calipers vs non sealed ones, with AP calipers, unless you never check them, the non dirt sealed ones will be fine. Lots of rally cars run them and they handle a lot harsher conditions than most road cars Quote Link to comment Share on other sites More sharing options...
TJM Posted July 17, 2013 Author Share Posted July 17, 2013 Hello Both kits will now be £1495.00 using AP Racing APF403 compeition pads or road equivelant. Other pads can be supplied but may incur some extra cost. I have these for both standard hubs or my Group 4 heavy duty hubs. Regards Tim Quote Link to comment Share on other sites More sharing options...
TJM Posted February 22, 2014 Author Share Posted February 22, 2014 (edited) Hello I have one kit in stock at a special price of £1350 (including DS3000 pads) for immediate despatch. P&P to UK Mainland £25.00 to include insurance. These kits have now gone up to £1595 for 2014. Regards Tim Edited February 22, 2014 by TJM Quote Link to comment Share on other sites More sharing options...
