Downhill Stall
Arkade
Hi all,
I'm running a 2.0 GT/E Manta B engine in an A and it seems to be running pretty smoothly apart from one hiccup. I've found that after going down long downhills, upon baking to a stop, she won't catch the idle and stalls. As I said before, this only seems to be after a long downhill so I'm pretty sure gravity must be having some sort of effect on something.
Anybody got any ideas?
are you running it on the fuel injection or on carbs. i had a similiar problem not long ago on a jeep ,the air box had been replaced for a k+n filter which was allowing more air flow, the original inlet piping is designed to offer ram induction this was allowing the mixture to go weak on closed throttle freewheeling down long hills. i took the k+n off fitted a factory air box and the problem went.
Fuel tank does not contain a swirl pot in an A, so maybe you are suffering low fuel pressure because the pump is sucking air, does it do it going up long hills ?
best thing is to get an suitable fuel pressure gauge plumbed in and watch what it does on hills.
Can you hear the pump racing at all ?
You're all overthinking it.
I would say sounds like:
1) Car is a little lean
2) Idle is a little low
3) Brake servos let air into the inlet manifold, long slopes = sustained braking and constant air into the manifold through vacuum hose.
4) That means less air flows through afm so less mixture hence stalls
also to confirm the servo fault theory see what happens when youre all warmed up & idling.pressing the brake pedal may change the idle speed.it should only do this whilst you are actually MOVING the pedal down.it should not cause any air to leak whilst pressed or released.ie the servo only needs to refil with vacuum when it needs it !
