Can Anyone Advise On Glowing Red Manifold & Exhaust :(
guysat
Please can anyone advise on glowing red manifold & exhaust :(
Have exchanged idle control valve & made no difference to be able to start
Today I stuck a new 600amh battery and she started, was quite rough to begin-with but started to smooth out after approx 1min. The exhaust note was very deep and load.......
After about 3mins of running @ 1400rpm I noticed the manifold and exhaust halfway under car was glowing RED
Switched off immediatly
After being excited about starting (First time in along time) now wondering whats wrong.
Theres no after burner fitted :D
I realise this is a 2.4 with 2.2 injection and a fast road cam fitted, but thats still no excuse for a red exhaust.....!
Been thinking about this :huh: , if the camshaft was a tooth out, would that hold the exhaust valves open while still burning fuel
Edited by guysat
another thing to check. the 2.2 system has a totally different injection temp sensor than a 2 litre gte. it has 2 elements rather than one. one controls the injection mixture.the other controls the idle speed (idle speed control box)the wrong type would cause a weird feedback loop & possibly make it go super lean ???????????? i assume you are using the correct 2.2 full setup.ie correct ecu,wiring,distributor & trigger box,(distributor has no centrifugal advance)(ignition advance control box,variable 3 terminal idle valve,no 5th injector.see haynes book for carlton 2.2 if req as it gives a pretty good write up on the differences over the 2 litre gte stuff. any part numbers or advice you need feel free to message me. ta
Hi
Yes this is a full 2.2 setup with the idle control box and distributor, have now spent approx 2.5 years trying to get this running correctly, but haven't had the red exhaust before, I have 2 idle control boxes, will try swapping them again tonight
you definately have the correct temp sensor. there should be a equal resistance circuit from either of the pins to earth.not just beween them.
Thats something I haven't checked, as the thermostat housing is from a Monza. I don't have a temp sensor connected to the radiator temp sensor as yet
Exhaust is definitely not blocked, new Jetex
Edited by guysat
Cam.in.head you are my Hero :thumbup
Have changed the temp sensor to the part No you recommend (Just happen to have in the garage,...) and she starts and runs great and even restarts again and again. Large smile on my face
Taken me 2.5 years to find that one out, Sensor has to feed ECU & Idle control units
Thank you so much, Pint on me @ billing :D
Edited by guysat
