Manta Diff Removal
tocca
this post might be too late and the deed has already been done, but i would suggest not welding up your diff.
unless your running huge power or using it on gravel rally satges then traction should not be a problem in most situations, if you are and your skint then weld it up.
much better to put in a limited, you can get them from Gripper diffs, this way you'll keep the Manta's fine handling, weld up the diff and you'll get understeer.
Diffs welded up, easy job really. Would have been easier in place but nicer job removing it. Was a mare to get out of my garage as its tight from yard to lane. No way on earth could you drive one daily. Goes sideways a lot easier now. Cant wait to do a drift day now! :D
