Daveyboy20 Posted March 18, 2014 Share Posted March 18, 2014 Hi guys - still putting 50 miles a day on my very low mk1 Cavalier.. Broke down he other day as the condensor was goosed - only 3 months old! Cheap Ebay rubbish! Apart from that and the fact it's so low I now need to re underseal most of the chassis it's been very good. I just wanted to try and work out what this slight niggle is... At low revs/light throttle it is a bit jerky. 2nd gear feels a bit 'rough' too. The engine is a 1.6 with a solex carb with electronic auto choke. If I floor it it's power delivery is smooth, but light throttle cruising (which is where this car really belongs!) is not that enjoyable. I was thinking vac leak but spraying Lynx around the carb a manifold appears to not affect the idle at all so I'm wondering if there is a common problem with these carbs that causes such issues? Vac advance is working, plugs, air filter, coil, leads, dizzy cap, rotor arm, points and condensor all new. Fuel cleaner has been through the system, it doesn't smoke, starts well and always ways has lead additive in. Cheers guys Quote Link to comment Share on other sites More sharing options...
Cavtastic Posted March 18, 2014 Share Posted March 18, 2014 Induction air leak! Quote Link to comment Share on other sites More sharing options...
garymanc Posted March 18, 2014 Share Posted March 18, 2014 silly question is it from the engine or the running gear Quote Link to comment Share on other sites More sharing options...
Daveyboy20 Posted March 18, 2014 Author Share Posted March 18, 2014 I just can't get the spray to make the idle raise! If it's a vac leak it's doing a bloody good job of hiding! Can't tell if it's drive train or engine, it's really low so I'd imagine the prop is at a funny angle but surely if it was drivetrain, booting it would make it worse? Or would it be like a snaking caravan and smooth out?! Quote Link to comment Share on other sites More sharing options...
garymanc Posted March 18, 2014 Share Posted March 18, 2014 might be worth checking your gearbox mounting as they go soft , mines was showing up at low speeds 1 Quote Link to comment Share on other sites More sharing options...
Daveyboy20 Posted March 19, 2014 Author Share Posted March 19, 2014 That's a good shout - I'd imagine it's a combination of both... Maybe the deo is burning up in the exhaust manifold before it can alter the idle - I'll try a spray from a cold start. Quote Link to comment Share on other sites More sharing options...
kenny dock Posted March 19, 2014 Share Posted March 19, 2014 i had issues similar to this, i had a vac leak at the manifold, unplugged factory opening on the manifold caused the issue. however i would bin the points / condenser and get an accuspark kit for £30 my points were a pain in the ass and caused my car to kangaroo at low revs. electronic points were the best thing i bought made the car run so much smoother. kenny Quote Link to comment Share on other sites More sharing options...
Daveyboy20 Posted March 20, 2014 Author Share Posted March 20, 2014 Unplugged opening? Where abouts was it? I crawled underneath last night and found the gearbox mount was split so that will be exaggerating the missfire I'd imagine. It's definately also got an engine miss at low revs, I just need to find that vac leak! Quote Link to comment Share on other sites More sharing options...
dynamytedan Posted March 21, 2014 Share Posted March 21, 2014 not an air leak on the throttle spindle ? check it for play . ht leads can play up at low revs check it in the dark for spark leaks . id would also fit an electronic thing instead of points , if your doing 50 miles a day it will pay for its self in saved fuel in a few months . Quote Link to comment Share on other sites More sharing options...
kenny dock Posted March 21, 2014 Share Posted March 21, 2014 Right under the manifold you will need a small mirror to see it from top. Fit electronic ignition asap. The see what your left with. No matter how hard I tried to get 0.7 Points gap, it was never right. Quote Link to comment Share on other sites More sharing options...
