Jack Posted December 28, 2014 Share Posted December 28, 2014 I have a sqeaky release bearing on my Manta and I have been told that it is a fairly invloved job so I may as well change all the clutch whilst I am at it rather than having to do it all again. Dont think it makes any difference what Manta it is but it is an early GT/E Hatch: Link to comment Share on other sites More sharing options...
Julian Posted December 28, 2014 Share Posted December 28, 2014 Is that a fact Jack? All Manta clutches are the same? That's another thing I didn't know! Link to comment Share on other sites More sharing options...
rutts Posted December 28, 2014 Share Posted December 28, 2014 you need the 5 speed clutch kit for a GTE. don't get 4 speed or 1.8 clutch kit. Link to comment Share on other sites More sharing options...
paulmanta Posted December 28, 2014 Share Posted December 28, 2014 (edited) Not being funny but if you cant master a window winder mech then please don't try a clutch ! The year of the mantas manufacture makes a difference to the clutch parts used so watch out for getting the wrong part, the friction plate could be one of a couple of diameters and the pressure plate could bolt on with 4 or 6 bolts and could be different diameters. I advise getting a proper garage to take out the rubber inspection grommet in the bellhousing and squirt a small amount of motorcycle chain lube on/into the release bearing and see if the squeak goes away. I suspect it will. Much like the winder problem, lubrication may well be the key here. Everyone likes a clean shiny car but they need oil/grease to make sure they work. Edited December 28, 2014 by paulmanta 2 Link to comment Share on other sites More sharing options...
